Main public logs
Combined display of all available logs of The E28 Wiki. You can narrow down the view by selecting a log type, the username (case-sensitive), or the affected page (also case-sensitive).
- 18:49, 20 July 2026 Tig talk contribs created page Steering (Created page with "=== Steering Boxes === Most E28s came with a 3.5 turn-to-turn ratio steering box. These can be identified with a silverish tag with red-ish writing. [http://RealOEM%20link https://www.realoem.com./bmw/enUS/showparts?id=DC74-USA---E28-BMW-535i&diagId=32_0137]. The tag on the box will have '''1 124 700.0''' on it like these <gallery> Standard E28 Steering Box.jpeg|Standard E28 Steering Box Standard E28 Steering Box Tag.jpeg|Standard E28 Steering Box Tag </gallery> Part...") Tag: Visual edit: Switched
- 18:40, 20 July 2026 Tig talk contribs created page File:635csi Steering Box.jpeg
- 18:40, 20 July 2026 Tig talk contribs uploaded File:635csi Steering Box.jpeg
- 18:40, 20 July 2026 Tig talk contribs created page File:M5 Steering Box.jpeg (M5 Steering Box Tag)
- 18:40, 20 July 2026 Tig talk contribs uploaded File:M5 Steering Box.jpeg (M5 Steering Box Tag)
- 18:35, 20 July 2026 Tig talk contribs created page File:Standard E28 Steering Box.jpeg
- 18:35, 20 July 2026 Tig talk contribs uploaded File:Standard E28 Steering Box.jpeg
- 18:34, 20 July 2026 Tig talk contribs created page File:Standard E28 Steering Box Tag.jpeg
- 18:34, 20 July 2026 Tig talk contribs uploaded File:Standard E28 Steering Box Tag.jpeg
- 19:46, 5 August 2025 Tig talk contribs created page File:8731055620 a669196e9a.jpg
- 19:46, 5 August 2025 Tig talk contribs uploaded File:8731055620 a669196e9a.jpg
- 19:44, 5 August 2025 Tig talk contribs created page M30 Engine Rebuild Tips & FAQ (Created page with "== Q: What's the best order of assembly of an M30 motor? == If you don't follow this order you will likely end up re-doing work. # Oil pump and chain. # Lower timing chain sprocket, guides, and timing chain. # Lower timing chain cover. Don't forget to install the brackets for the timing sensor and shackle. # Grub screw, AC compressor mount, PS/Alternator mount # Rear main seal. # Oil pan # Install harmonic balancer temporarily so you can see crank TDC. NOTE: in my pic...")
- 16:16, 11 January 2025 Tig talk contribs moved page How Do I Read my Temperature Gauge? to Temperature Gauge - How to Read It?
- 16:14, 11 January 2025 Tig talk contribs moved page E28 Spark Plug FAQ to Spark Plug FAQ (Misspelled title)
- 16:05, 11 January 2025 Tig talk contribs created page Talk:The E28 Wiki (Started convo.)
- 19:51, 8 January 2025 Tig talk contribs created page File:E9.jpg
- 19:51, 8 January 2025 Tig talk contribs uploaded File:E9.jpg
- 01:16, 6 January 2025 Tig talk contribs created page MediaWiki:Timeless.css (Created page with "All CSS here will be loaded for users of the Timeless skin: #mw-header *, #mw-site-navigation *, #mw-related-navigation * { font-family: 'Segoe UI','Segoe UI Emoji','Segoe UI Symbol','Lato','Liberation Sans','Noto Sans','Helvetica Neue','Helvetica',sans-serif; } Avoid cutting off letters with descenders: g,j,p,q,y: #personal h2 span { height: 1.5em; position:relative; bottom:0.1em } Triangle position patch: #personal h2::after { positi...")
- 01:15, 6 January 2025 Tig talk contribs changed group membership for Tig from bureaucrat and administrator to bureaucrat, administrator and interface administrator
- 17:43, 3 January 2025 Tig talk contribs deleted page File:Banner small.jpg (content was: "", and the only contributor was "Tig" (talk))
- 17:43, 3 January 2025 Tig talk contribs deleted page File:Mye28 logo.gif (content was: "", and the only contributor was "Tig" (talk))
- 17:43, 3 January 2025 Tig talk contribs deleted page File:E28exhaust.xls (content was: "", and the only contributor was "Tig" (talk))
- 17:43, 3 January 2025 Tig talk contribs deleted page File:535i Maint Data Sheet.pdf (content was: "", and the only contributor was "Tig" (talk))
- 17:42, 3 January 2025 Tig talk contribs deleted page File:E30manualhaynescomplete.pdf (content was: "", and the only contributor was "Tig" (talk))
- 17:37, 3 January 2025 Tig talk contribs created page File:Bmw-Torque-Specs all sizes.pdf
- 17:37, 3 January 2025 Tig talk contribs uploaded File:Bmw-Torque-Specs all sizes.pdf
- 17:34, 3 January 2025 Tig talk contribs created page File:E30manualhaynescomplete.pdf
- 17:34, 3 January 2025 Tig talk contribs uploaded File:E30manualhaynescomplete.pdf
- 17:31, 3 January 2025 Tig talk contribs created page File:535i Maint Data Sheet.pdf
- 17:31, 3 January 2025 Tig talk contribs uploaded File:535i Maint Data Sheet.pdf
- 17:27, 3 January 2025 Tig talk contribs created page File:E28exhaust.xls
- 17:27, 3 January 2025 Tig talk contribs uploaded File:E28exhaust.xls
- 17:26, 3 January 2025 Tig talk contribs created page File:Banner small.jpg
- 17:26, 3 January 2025 Tig talk contribs uploaded File:Banner small.jpg
- 17:22, 3 January 2025 Tig talk contribs created page File:Mye28 logo.gif
- 17:22, 3 January 2025 Tig talk contribs uploaded File:Mye28 logo.gif
- 16:34, 1 January 2025 Tig talk contribs created page File:M20B27 e2i Swap.jpg
- 16:34, 1 January 2025 Tig talk contribs uploaded File:M20B27 e2i Swap.jpg
- 16:02, 1 January 2025 Tig talk contribs created page M20 - e2i Conversion (Created page with "The '''M20 "e2i" conversion''' is a popular modification for BMW enthusiasts seeking to enhance the performance of the M20B27 engine found in "eta" models by integrating components from the higher-revving M20B25 "i" engine. This conversion combines the torque-rich characteristics of the eta engine with the improved airflow and higher RPM capabilities of the "i" engine. ---- === Key Features === * '''Increased Displacement''': Retains the 2693cc displacement of the M20B...") Tag: Visual edit
- 15:57, 1 January 2025 Tig talk contribs created page Subframe and Steering Reinforcement (Created page with "''Based on this post by George:'' e '''Subframe and Steering Reinforce'''rovides a comprehensive overview of methods to address and prevent steering box bracket failures in BMW E28 models. This guide consolidates insights from the MyE28.com community, detailing various reinforcement techniques, necessary tools, and materials. '''Introduction''' The steering box bracket in BMW E28 vehicles is prone to failure, leading to steering issues and potential safety hazards. C...") Tag: Visual edit
- 15:51, 1 January 2025 Tig talk contribs created page Acronyms (Created page with "This page is a complete glossary of acronyms related to the BMW E28 community, compiled from the MyE28.com forum thread [https://www.mye28.com/viewtopic.php?t=96021 BMW / MyE28.com Acronyms]. It includes every acronym from the original post and all follow-up comments. ---- === Acronyms and Their Meanings: === * '''A/C''': Air Conditioning * '''A/D''': Analog/Digital * '''AAV''': Additional Air Valve or Auxiliary Air Valve * '''AB''': Airbag * '''ABS''': Anti-lock Braki...") Tag: Visual edit
- 21:35, 31 December 2024 Tig talk contribs moved page E28 Accessories to Accessories
- 21:34, 31 December 2024 Tig talk contribs created page E28 Accessories (Created page with "[https://www.mye28.com/tech/E28_Accessories_NA.pdf E28 Accessories Brochure (NA)] Category:E28 Information") Tag: Visual edit
- 15:32, 31 December 2024 Tig talk contribs deleted page E28 Information (content was: "#REDIRECT Category:E28 Information", and the only contributor was "Tig" (talk))
- 15:32, 31 December 2024 Tig talk contribs deleted page Tech FAQ (content was: "#REDIRECT Category:Tech FAQ", and the only contributor was "Tig" (talk))
- 15:25, 31 December 2024 Tig talk contribs moved page E28 Information to Category:E28 Information
- 15:22, 31 December 2024 Tig talk contribs moved page Tech FAQ to Category:Tech FAQ
- 14:55, 31 December 2024 Tig talk contribs created page How Do I Read my Temperature Gauge? (Created page with "none|frame|Approximate E28 Temperature Gauge Readings") Tag: Visual edit
- 14:55, 31 December 2024 Tig talk contribs created page File:E28 Temperature Gauge.jpg
- 14:55, 31 December 2024 Tig talk contribs uploaded File:E28 Temperature Gauge.jpg
