This page is a complete glossary of acronyms related to the BMW E28 community, compiled from the MyE28.com forum thread BMW / MyE28.com Acronyms. It includes every acronym from the original post and all follow-up comments.
Acronyms and Their Meanings:
- A/C: Air Conditioning
- A/D: Analog/Digital
- AAV: Additional Air Valve or Auxiliary Air Valve
- AB: Airbag
- ABS: Anti-lock Braking System
- ACC: Active Check Control
- ACS: AC Schnitzer
- ADB: Automatic Differential Braking
- AE: Angel Eyes
- AFM: Air Flow Meter
- AFR: Air to Fuel Ratio
- ALC: Automatic Light Control
- AMHIK: Ask Me How I Know
- ARS: Active Roll Stabilization
- ASC: Automatic Stability Control
- AT: Automatic Transmission
- ATF: Automatic Transmission Fluid
- AWD: All Wheel Drive
- BBK: Big Brake Kit
- BFH: Big effin hammer
- BLS: Brake Light Switch
- BMW: Bayerische Motoren Werke
- BST: Battery Safety Terminal
- CA: Customer Advisor (salesperson)
- CAB: Control Arm Bushing
- CAI: Cold Air Intake
- CAS: Car Access System
- CBC: Cornering Brake Control
- CCFL: Cold Cathode Fluorescent Lighting
- CCM: Check Control Module
- CD: Control Display
- CDC: Compact Disk Changer
- CDV: Clutch Delay Valve
- CEL: Check Engine Light
- CF: Carbon Fiber
- CLS: Central Locking System
- COP: Coil On Plug
- CPO: Certified Pre Owned
- CPS: Crank Position Sensor
- CSB: Center Support Bearing
- CSI: Cold Start Injector
- CSL: Coupe Sport Lightweight
- CSV: Cold Start Valve
- CTS: Coolant Temp Sensor
- CVT: Continuously Variable Transmission
- CWP: Cold Weather Package
- DAE: Daytime Angel Eyes
- DBC: Dynamic Brake Control
- DBS: Dynamic Braking System
- DCS: Dealer Communication System
- DD: Daily Driver
- DDE: Digital Diesel Electronics
- DIS: Direct Ignition System
- DIY: Do It Yourself
- DME: Digital Motor Electronics
- DMM: Digital Multi Meter
- DOHC: Double Over Head Camshafts
- DRL: Daytime Running Lamps
- DSC: Dynamic Stability Control
- DTC: Dynamic Traction Control
- DTM: Deutsche Tourenwagen Meisterchaft (German Touring Car Championship)
- EAM: Electrostatic Airflow Meter
- ECM: Engine Control Module
- ECU: Electronic Control Unit
- ED: European Delivery
- EDFC: Electronic Dampening Force Controller
- EDIS: Electronic Distributorless Ignition System
- EFI: Electronic Fuel Injection
- EPROM: Erasable Programmable Read Only Memory
- ETA: Efficiency (from the η for the Greek letter eta, as in 528e)
- ETK: Electronic Parts Catalog
- ETM: Electrical Troubleshooting Manual
- FAD: Fat Ass Driver
- FI: Forced Induction
- FTL: For The Loss
- FTW: For The Win
- FWD: Front Wheel Drive (only applies to MINI!)
- GLTB: Good Luck To Buyer
- GLWS: Good Luck With Sale
- H/K: Harmon/Kardon
- HDR: High Dynamic Range
- HFM: Hot Film Meter
- HID: High Intensity Discharge
- HM: Hotwire Meter
- HPS: Head Protection System
- Hz: Hertz (Cycle)
- i: Fuel Injection (as in 535i)
- IAC: Idle Air Control (valve) (ICV)
- I-Bus: Information Bus
- ICM: Idle Control Module
- ICV: Idle Control Valve
- IKE: Instrument Cluster Electronics
- IR: Infrared
- IRS: Infrared Locking System
- ISC: Idle Speed Control
- ISIS: Intelligent Safety Integration System
- ITB: Individual Throttle Body
- LAM: Laser Airflow Meter
- LCAB: Lower Control Arm Bushing
- LCL: Low Coolant Light
- LCM: Lamp Check Module
- LDP: Leak Diagnosis Pump
- LED: Light Emitting Diode
- LEO: Law Enforcement Officer
- LEV: Low Emissions Vehicle
- LHD: Left-Hand Drive
- LSD: Limited Slip Differential
- MAF: Mass Air Flow sensor
- MIA: Missing In Action
- MT: Manual Transmission
- NAV: Navigation
- NLA: No Longer Available
- OBC: On Board Computer
- OBD: On Board Diagnostics
- OEM: Original Equipment Manufacturer
- OIL: Oh, I Like
- OOP: Out Of Pocket
- OT: Off Topic
- PB: Parking Brake
- PCB: Printed Circuit Board
- PDC: Park Distance Control
- PEM: Power Electronics Module
- PITA: Pain In The Ass
- PSI: Pounds per Square Inch
- PTFE: Polytetrafluoroethylene
- RDS: Radio Data System
- RHD: Right-Hand Drive
- RIM: Rim Impact Monitor
- RWD: Rear Wheel Drive
- SAP: Secondary Air Pump
- SAV: Sports Activity Vehicle
- SCCA: Sports Car Club of America
- SES: Service Engine Soon
- SLS: Self Leveling Suspension
- SMG: Sequential Manual Gearbox
- SOP: Start Of Production
- SUV: Sport Utility Vehicle
- SWMBO: She Who Must Be Obeyed
- TPS: Throttle Position Sensor
- TSB: Technical Service Bulletin
- VANOS: Variable Nockenwellen Steuerung (Variable Camshaft Timing)
- VIN: Vehicle Identification Number
- WB: Wheelbase
- WOT: Wide Open Throttle
- ZF: ZF Friedrichshafen AG (manufacturer of driveline and chassis technology)
The list includes all acronyms mentioned in the forum thread and its comments. If there are additional terms to include or corrections to make, feel free to contribute!
