Based on this post by George:
e Subframe and Steering Reinforcerovides a comprehensive overview of methods to address and prevent steering box bracket failures in BMW E28 models. This guide consolidates insights from the MyE28.com community, detailing various reinforcement techniques, necessary tools, and materials.
Introduction
The steering box bracket in BMW E28 vehicles is prone to failure, leading to steering issues and potential safety hazards. Common failure modes include cracking or complete detachment of the bracket from the subframe. Addressing this issue promptly is crucial to maintain vehicle safety and performance.
Reinforcement Methods
  1. Bolt and Spacer Method:
    • Description: This method involves inserting a long bolt through the subframe with a spacer positioned between the top of the subframe and the bottom of the steering box bracket. Tightening the bolt creates compression, increasing friction to prevent movement.
    • Considerations: Suitable only if the bracket is intact. Not recommended for cracked or broken brackets, as it relies solely on friction to prevent movement.
  2. Mwrench Steel Dowel Reinforcement:
    • Description: Developed by Ed Raether, this method uses a steel dowel inserted through the subframe, providing a solid anchor point for the steering box. The dowel can be installed with or without subframe removal.
    • Installation Options:
      • Without Subframe Removal: The dowel is inserted and secured without welding, allowing for a quicker installation.
      • With Subframe Removal: Allows for welding both ends of the dowel to the subframe, offering enhanced security.
    • Advantages: Provides a robust and permanent solution, preventing movement even if the original bracket is compromised.
  3. Subframe Boxing:
    • Description: Involves welding additional steel plates to reinforce the existing bracket, effectively "boxing" it for added strength.
    • Considerations: Requires subframe removal and is only feasible if the original bracket is intact. This method is labor-intensive and may not offer significant advantages over the Mwrench dowel reinforcement.
Installation Procedure for Mwrench Steel Dowel
Tools and Materials Needed:
  • Mwrench steel dowel
  • 6-inch long 15/32-inch bolt and corresponding nut (7/16-inch bolt can be used as an alternative)
  • Angle grinder or wire brush for surface preparation
  • Mallet for dowel insertion
  • Welding equipment (if opting for welded installation)
Steps:
  1. Preparation:
    • Clean both sides of the subframe around the bracket area using a wire brush or angle grinder to remove paint and debris, ensuring a clean surface for welding or dowel insertion.
    • Sand the dowel slightly to facilitate a snug fit.
  2. Dowel Insertion:
    • Align the dowel with the existing hole in the subframe.
    • Gently tap the dowel into place using a mallet until it sits flush within the subframe.
  3. Steering Box Alignment:
    • Position the steering box to align with the dowel.
    • Insert the bolt through the dowel and secure it with the nut, ensuring the steering box is firmly attached.
  4. Welding (Optional):
    • If the subframe is removed, weld both ends of the dowel to the subframe for additional reinforcement.
    • Ensure proper welding techniques to maintain structural integrity.
Additional Considerations
  • Inspection: Regularly inspect the steering box bracket and reinforcement to ensure continued integrity, especially after performing suspension or steering work.
  • Professional Assistance: If unsure about performing the reinforcement, seek assistance from a professional mechanic experienced with BMW E28 models.
Conclusion
Reinforcing the steering box bracket is essential for maintaining the safety and performance of BMW E28 vehicles. The Mwrench steel dowel method offers a durable solution, accommodating various conditions of the existing bracket. Proper installation and regular inspections will ensure the longevity of the reinforcement.
For detailed discussions, images, and community insights, refer to the original forum thread: Subframe and Steering Reinforcement.
