License for Vector
freedom to share and change it.  By contrast, the GNU General Public
software--to make sure the software is free for all its users.  This
using it.  (Some other Free Software Foundation software is covered by
the GNU Lesser General Public License instead.)  You can apply it to
price.  Our General Public Licenses are designed to make sure that you
you have.  You must make sure that they, too, receive or can get the
source code.  And you must show them these terms so they know their
software.  If the software is modified by someone else and passed on, we
patents.  We wish to avoid the danger that redistributors of a free
program proprietary.  To prevent this, we have made it clear that any
under the terms of this General Public License.  The "Program", below,
language.  (Hereinafter, translation is included without limitation in
the term "modification".)  Each licensee is addressed as "you".
covered by this License; they are outside its scope.  The act of
    License.  (Exception: if the Program itself is interactive but
These requirements apply to the modified work as a whole.  If
sections when you distribute them as separate works.  But when you
    to distribute corresponding source code.  (This alternative is
making modifications to it.  For an executable work, complete source
control compilation and installation of the executable.  However, as a
except as expressly provided under this License.  Any attempt
signed it.  However, nothing else grants you permission to modify or
distribute the Program or its derivative works.  These actions are
prohibited by law if you do not accept this License.  Therefore, by
these terms and conditions.  You may not impose any further
excuse you from the conditions of this License.  If you cannot
may not distribute the Program at all.  For example, if a patent
implemented by public license practices.  Many people have made
countries not thus excluded.  In such case, this License incorporates
of the General Public License from time to time.  Such new versions will
Each version is given a distinguishing version number.  If the Program
Software Foundation.  If the Program does not specify a version number of
to ask for permission.  For software which is copyrighted by the Free
make exceptions for this.  Our decision will be guided by the two goals
FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.  EXCEPT WHEN
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.  THE ENTIRE RISK AS
TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU.  SHOULD THE
  To do so, attach the following notices to the program.  It is safest
    Copyright (C) <year>  <name of author>
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
parts of the General Public License.  Of course, the commands you use may
necessary.  Here is a sample; alter the names:
proprietary programs.  If your program is a subroutine library, you may
library.  If this is what you want to do, use the GNU Lesser General
