Electrical FAQs
FAQ Covers
Service Indicator Reset Reset the Oil Service and Inspection lights
SI Board Replacement Replace a failed service-interval board
E28 Charging System Alternator, regulator, battery light, voltage drop
On-Board Computer (OBC II) Time, units, CODE, range calibration, PPPP
OBC I Went Dead Inline fuse inside the early OBC
Radio Wiring Aftermarket radio on the factory harness
Cruise Control Doesn't Work Brake-light ground, pedal switches, brain, servo
Euro Headlight Wash/Wipe Troubleshooting Euro headlight washers and wipers
Turn Signals Don't Work But Hazards Do Fuse 11 or turn-signal stalk
Check Brake Lights Come On at Every Start Normal E28 startup lamp check
Oil Pressure Light Flickers Sender, wiring, or real low pressure
Temperature Gauge Troubleshooting How to read it, sender test, SI board, grounds
Power Window Issues Motors, regulators, switches
Auto Won't Shift After Cluster Swap Auto stuck in 1st after a cluster swap
Car Won't Start Where to start when it will not crank/start
Cold Weather Chime Ice-warning gong below 37 °F
Spark Plug FAQ Which spark plugs to use
M20 - e2i Conversion M20B27 eta-to-i conversion
E28 Electrical Troubleshooting Manuals (ETM)
ETMs are the go-to resource for tracking down electrical issues in E28s. They appear to only have been printed for US market vehicles, so euro cars may have some minor differences.
E28 Schaltplänes
The Schaltplänes, German for "circuit diagrams", are the BMW factory wiring diagrams. These can be very useful, however they are drawn for a technical audience and not for the faint of heart. We recommend using the ETM unless that doesn't solve your problem.
Scanned copies, originally from the BMW Group Archive, are available in German below. German print copies can occasionally be found on German eBay. English print copies are rare, if you have any please send a PM to Galahad on the forums or reach out to the Holy Grail Labs support email.
E28 Related Electrical Info and Diagrams
Other Model ETMs
E21 Wiring Diagrams
The wiring diagrams are between the more traditional ETM layout and the Schaltplänes.
The E21 Schaltplänes have drawing errors in the fog light wiring in the fuse box, current best info is the wiring diagrams are correct to the cars.
