Suspension FAQs
FAQ Covers
Subframe and Steering Reinforcement Steering-box bracket / subframe reinforcement
Steering Steering boxes and identification
Steering Knock When Turning Knock or clunk in the steering when turning
Ground Control Coilover Install Ground Control coilover install
Independent front and rear suspension is used, with Macpherson struts at the front and a semi-trailing arm design for the rear.
The front suspension was upgraded to use dual links at the bottom of the strut, as first seen on the E23 7 Series. This increases steering offset while cornering, to improve steering feel. Double-acting shock absorbers, coil springs and a front anti-roll bar are used.
The rear suspension is mounted on a delta beam that is connected to the body with three screws in rubber bearings, that have longitudinal play. Some models have a rear anti-roll bar.
The steering on most models is a speed-dependent recirculating ball power steering system made by ZF Friedrichshafen. The 518i has a Gemmer steering system with a double enveloping worm gear, also made by ZF.
Wheel sizes are 14-inch (16-inch for the M5 model) or 390mm Michelin TRX. All rims have 22 mm positive rim offset.
Front
Steering
See Steering.
Rear
