Interior FAQs
FAQ Covers
On-Board Computer (OBC II) Time, units, CODE, range, PPPP
OBC I Went Dead Inline fuse inside the early OBC
Odometer Gear Replacement Replace stripped cluster odometer gears
Radio Wiring Aftermarket radio on the factory harness
Cruise Control Doesn't Work Brake-light ground, pedal switches, brain, servo
Dashboard Cracks Dash pad cracks
Power Window Issues Motors, regulators, switches
Power Headrests Won't Move Drive-cable engagement in the motor
No Heat From Dash Vents Dash vents designed not to blow heat
Heat Works at Idle But Not at Speed Heater valve / vacuum / water valve
Heater Motor Squeals Blower motor clean, lube, or replace
Cruise control, an on-board computer (to display trip information), and a "check control" panel (to alert the driver about fluid levels and lighting faults) were introduced to the 5 Series on the E28. The glazing is made of single-pane safety glass, the windscreen has laminated glass.
Interior Materials and Colors Availability (EU)
Vinyl 1982 1983 1984 1985 1986 1987
0165 Perlbgeige X X X X
0126 Piniengrün X X X X X X
0164 Nutria X X X
0005 Schwarz X X X X X X
0105 Pacific X X X X X X
Cord Fabric (518i and Gov. only) 1982 1983 1984 1985 1986 1987
0172 Perlbgeige X X X
0125 Piniengrün X X X X X X
0171 Nutria X X X
0120 Anthrazit X X X X X X
0121 Pacific X X X X X X
Velour "Fischgrät Pattern" 1982 1983 1984 1985 1986 1987
0170 Perlbgeige X X X X
0133 Piniengrün X X X X X X
0169 Nutria X X X
0129 Anthrazit X X X X X X
0130 Pacific X X X X X X
Leather 1982 1983 1984 1985 1986 1987
0206 Perlbgeige X X X
0209 Lama X X X
0205 Nutria X X X
0208 Taurusrot X
0203 Schwarz X X X
0204 Pacific X X X
0256 Cardinalrot X
Velour w/ vertically woven stripes 1982 1983 1984 1985 1986 1987
0260 Perlbgeige X
0261 Piniengrün X
0259 Nutria X
0257 Anthrazit X
0258 Pacific X
0262 Perlbgeige X
0263 Piniengrün X
0264 Nutria X
0262 Anthrazit X
0263 Pacific X
